Home > Puma (Tdci) > I need a favour!!
Co1
I need a favour!!
As you might have seen from other threads, I’m installing air con to my puma. The instructions when it comes to dressing the loom in are none existent, and there is no detail on how the pipes are supported either.
So… for those of you with air con I’d appreciate a massive favour! Can you take a few pics under the bonnet of where the pipes are supported/clipped and which route the cables take.
Massive thanks in advance.
Col
Post #911913 11th Jul 2021 12:56pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
If you would of asked yesterday I was right where you needed to be.
I’ll get you photos later if nobody else has obliged.
I know one goes on the turbo side and another tube goes over the other side of the engine (and the valve is under the wing nearly) Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #911934 11th Jul 2021 5:17pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Here are some photos of my AC pipes and cables. You may notice the turbo is missing right now.
Post #911936 11th Jul 2021 5:38pm
Co1
Thanks both, very much appreciated.
Kevlar: I assume you have to take the air filter box out to install the pipe from the condenser to the back of the compressor?
I’d love to see more, as many angles as possible wouldn be great, especially the point at which the brackets and clips attach.
Col
Post #911937 11th Jul 2021 5:51pm
Kevlar
Hi
I can take more pics tomorrow in the mean time this page shows where the brackets go on the pipes
https://www.lrworkshop.com/diagrams/land-r...oses_44971
I have never installed AC system mine is factory fitted so not sure about the process.
Kev
Post #911940 11th Jul 2021 5:57pm
Dinnu
I can get a couple of pictures on Tuesday. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #911944 11th Jul 2021 6:08pm
Co1
Kevlar wrote:
Hi
Kev
Thanks Kev. I have the brackets on the hoses, I wanted to know where they attach to the body.
Thanks Dinnu, that would be great.
Post #911945 11th Jul 2021 6:23pm
Race.it
Does this help you any? Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #911946 11th Jul 2021 6:27pm
Co1
Great stuff Race.it. Very much appreciated.
Post #911955 11th Jul 2021 7:29pm
Dinnu
Hi Co1, probably not in order, but here are some photos.
The compressor clutch plugs into the harness, where I am pointing with my finger.
If you need any clarification let me know.
Post #912143 13th Jul 2021 8:08am
Co1
Brilliant Dinnu, much appreciated.
Post #912155 13th Jul 2021 9:45am
Dinnu
Welcome Co1.
Fyi, my nephew had an AC retrofitted to his Defender, but I do not know what brand. 3rd picture shows a refrigerant line from the dryer that goes to the cabin. In mine, the line passes under the wing, over the windscreen washer reservoir. On his, the line is visible all the way. I think it is more of an assembly error by the ‘professional’ company that installed it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #912157 13th Jul 2021 10:03am
