Home > Technical > Stuck with a rear brake issue (or maybe an ABS issue)
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Help sounds like a good place to start.
Currently on holiday up near Mallaig and the rear brakes on my 110 have seized on. Brake pedal has gone really hard and having nursed it the last little bit back to the campsite the rear wheels are hot (and clearly the brakes behind). Oddly enough the fronts appear to be fine (cool to the touch).
I've called the national breakdown company who're going to dispatch a local mechanic to have a look, Any pointers on where to start?
Could make it interesting getting home on Sun with the Penman as well. Shocked
Thanks Keith
Post #911613 9th Jul 2021 12:34pm
Dinnu
I do not think that ceased rear caliper would have any effect on the brake pedal feel.
So might be a master cylinder issue, not allowing the rear circuit pressure to relieve back into the reservoir. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #911624 9th Jul 2021 1:39pm
excossack
Years ago I had this on my Lada Niva. The trick at the time was to place one washers between the master and brake slave to get me home.
Turned out the pushrod didn't have enough play and caused the brakes to come and stay on but this was all four wheels, Maybe due to the unique brake setup on the Lada. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #911626 9th Jul 2021 1:53pm
Keith5
The local mechanic has been out and had a look, the pistons have pushed back in freely and brakes appear to operate without binding however the pedal now feels soft.
There's a continued softness in the pedal even when the engine is off and the residual servo effect has been depleted.
No warning lights (TC or ABS) and there's plenty fluid in the reservoir. Could it be the ABS module where the brake lines start? Keith
Post #911627 9th Jul 2021 2:02pm
Dinnu
I overlooked the ABS module in my reply. I know nothing on ABS to advise anything. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #911628 9th Jul 2021 2:07pm
Keith5
I'll try a short drive around the site once it's all gone cold and see what happens.
Worst case it will all go back on a flatbed Keith
Post #911638 9th Jul 2021 3:33pm
Keith5
So a quick drive up and down the site tells me.....
Rear brakes are now free but there is loads of travel in the pedal with or without the engine running. Very soft for the first 75% or more then you get the feel of the brakes increasing the resistance.
I can still get the brakes to work when the pedal is nearing the end of it's travel but I'm not convinced on what power I'm going to get out of them so it's recovery I think.
I'm guessing that I'm needing to look more at the Master cylinder, servo or ABS module etc Keith
Post #911684 9th Jul 2021 7:11pm
Dinnu
Did perhaps the mechanic open the bleed screw? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #911687 9th Jul 2021 7:35pm
Keith5
I believe he just pushed the pads back in.
I'm beginning to suspect Master cylinder as the likely candidate, but given I've got a recovery option that also covers the trailer I think that's going to be plan A. Keith
Post #911702 9th Jul 2021 9:06pm
jst
I would be checking the piston length inside the servo that actuates the mc.
Something here or relationship between two could be issue, though that would usually result in front locking first.
Hard pedal would suggest lockup in system with too much pressure . Seized calipers rear would not make pedal rock hard.
It then being very soft, post mech visit would suggest air into system. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #911716 10th Jul 2021 6:06am
