![]() | Home > Puma (Tdci) > The best gear for normal driving |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 607 ![]() ![]() ![]() |
I do most of the time if I'm on the flat. No problems so far in nearly 70k miles. https://instagram.com/bentheoandrews
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 167 ![]() ![]() ![]() |
Me too, been fine for the last 2 years
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
When unladen I used to do that all the time in my previous 2.4 90HT on standard 235/85x16 tyres I had very little additional weight from “accessories”. Second felt right for moving away on the level or down an incline. Never experienced problems.
Now drive a 2.4 110SW and whilst the gearing feels the same, I’m conscious of the greater unladen weight of the larger vehicle. Hence I have reverted to first gear to get the wheels in motion. And that’s basically all I use first for - to overcome initial inertia. I then short shift into second. Never found that method necessary in the 90 though. |
When I first saw the title of your thread I thought you might be asking about top hat and tails?
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4288 ![]() ![]() ![]() |
1st gear pull away all the time for me. Use the anti stall and no throttle to get the clutch engaged, then power away.
On a separate note, the anti stall is a really great feature for a number of reasons, hill starts and slow speed manoeuvring are all brilliant, having the the ability to load the transmission against the brake without fear of stalling has a number of uses off road too. 2007 110 TDCi Station Wagon XS |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 ![]() ![]() ![]() |
Yep. Agree on the benefits of anti-stall. It's a great thing to have, amazing how well it works pulling you uphill on idle. Handy if stuck in traffic too, a few less pushes of the clutch peddle.
I use 2nd gear to pull away from rest on a flat if I want to get away quickly like a busy roundabout or to whizz in front of another vehicle. With the Alive tune it takes off pretty quickly ![]() |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1247 ![]() ![]() |
So does the anti stall work all of the time in high range? I thought it was a low box first feature? 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17849 ![]() ![]() ![]() |
Yes.
You're thinking of the idle jack, which is an entirely different thing. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2420 ![]() ![]() |
It works if in first or second in high or low range. I love it in slow moving traffic, it’s just like having an auto box.
well you learn something every day. Having thought about it I cant remember a time I stalled it. Clearly I have been getting some help but did not realise it
![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Was always second for me too, unless uphill. When I bought it I got the 1/2 day offroad experience and the instructors there said the same. Never any issues with it in the 10 years I had it until some light fingered %$£&^%$ had away with it....
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3623 ![]() ![]() ![]() |
And for those people who didn't know what 'Idle Jack' was, I will save you the search
https://www.defender2.net/forum/post493899.html Use second for pulling away sometimes, not always. |
Thanks for that Rashers. Idle Jack was a new one on me
Me too
