- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Niels906
So I changed the brake vacuum pump. All went well. Did not take of the fan, but eased the tensioner to get the belt off the pulley. Changed the pump, changed the gasket, tinkered with the brake vacuum pipe for quite some time, but managed to get it off in the end. Assembled everything, started the engine only to be annoyed by hearing this sound which I can’t identify. Any one able to help me on this?
https://imgur.com/a/4wRIywk
Thanks in advance.
2nd Jul 2021 7:06pm |
lohr500
Cant help on the sound, but I would look to reposition that wiring loom where it is rubbing on the hose sleeve.
It might never wear right through the hose, but then again ........
3rd Jul 2021 5:36pm |
