Home > Maintenance & Modifications > Extended rain gutter
Terryt
For your general amusement. Spent a bit of time wondering about the joys of rain water running down the pillars and into the door seals. So new seals fitted and dum dum all of which works rather well . So have if stood in the rain watching it poor out of the gutter down the side and into the seal I thought..,I’d have a play with extending the gutter. I’ve some side panels left from fitting side lockers and window. I wanted something fairly discreet.
Early days yet and it’s only held on the blue tac plan is to finish painting and laquer it then steel weld it to the gram and tiger seal . Initial trial worked ok .
Post #910255 1st Jul 2021 9:45am
macfrank
I like that Thumbs Up I'm in the unfortunate position of having two rain gutters dripping down the A pillar and also directly on the floor mat (only with door open mind you Smile ), because of the pop-top roof.
Used a bit of dum dum to model rain gutter extensions. Now it pours along the windscreen seal, window blocks and down the bonnet. No sure if've just replaced one evil with another Confused
Post #910280 1st Jul 2021 1:53pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
See https://www.defender2.net/forum/topic56625.html for info about a solution using 16mm plastic trunking
plus photos from the originator's gallery:
Post #910291 1st Jul 2021 4:37pm
HardCharger
Can we see more details on this? The original post I saved no longer has the details and does not make any sense anymore. I've recently been having water in the front passenger side (right side, I'm LHD) I've sealed the roof seams and the windscreen to firewall seam. Even renewed the seals behind the window blocks. For some reason, I'm still getting water in there. I'm hoping this mod, long over due actually, can remedy my problems.
Thanks Thumbs Up
Post #910378 2nd Jul 2021 5:44am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Hardcharger, sounds like your having the same issue I've had previously. Dealer traced is back to water getting in through the heater in take. They sealed around the join circled (badly) in the pic below and fixed the issue
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #910414 2nd Jul 2021 9:35am
Terryt
2017 can’t think why I didn’t pick up on that .. oh well my mk 7 is alive and well working well
Post #910516 2nd Jul 2021 9:04pm
nitram17
Its hard to see in that photo ..does that trunking stop the water dripping and sends it back along the guttering?
Post #910537 2nd Jul 2021 11:22pm
macfrank
I don't think so, as the gutter would eventually overflow.
It's more about redirecting the flow. I found a picture of my dum-dum bodge (on the pop-top's lower gutter which is very similar to the original). The water usually takes the orange path and into the door seal. The black lump diverts it along the blue line, you can barely see it, down the A pillar.
Post #910542 3rd Jul 2021 6:03am
Terryt
Nice shot ..mate . That’s the issue I was having having extended the gutter mine now flows out onto the screen and away from the A pillar..
Post #910544 3rd Jul 2021 7:27am
nitram17
hi thanks from the picture i wasn't sure if the gutter was open allowing the rain to fall down the screen(white arrow looked like a hole) Very clear now and great mod..what did you paint it with?
Post #910550 3rd Jul 2021 8:03am
HardCharger
I haven't checked this yet, thanks Rosco, it's now on my to-do list as well Thumbs Up
Post #910909 6th Jul 2021 4:30am
I've not previously heard of the joint identified in the picture letting water in, but the joint between the duct from the wing to the heater fan box and the fan box itself is notorious for leaking. It has a rectangular foam seal which on many vehicles is squashed flat on one side but doesn't fill the gap on the other.
There are several threads on this joint on the forum.
Post #910933 6th Jul 2021 8:32am
macfrank
Just saw this Grenadier part on LR workshop's youtube channel.
Seems to be a snap-on plastic thingy.
Idea for an aftermarket Defender part?!
Post #912537 15th Jul 2021 6:02pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I've just stumbled across this thread, for the avoidance of doubt, is the trunking mod simply to provide something for the water to drip off as shown in blue? I know water has a tendency to track back along the gutter and drip into the footwell (as shown in red).
It looks a good little mod, I suppose that a formed return on the gutter (pointing downwards) would have the same effect? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #945806 14th Mar 2022 10:39pm
Terryt
Not sure about that trunking .. mine extends over the rubber .. and since that and sealing the gap between the bulkhead and wing I’ve had two dry footwells ever since.
Post #945820 15th Mar 2022 8:18am
