![]() | Home > Technical > Alarm issues - part number assistance required |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17872 ![]() ![]() ![]() |
I think that the door switch is one of those parts which hasn't changed much over time, and according to lrcat it would appear to be AFU4241L.
Info supplied without warranty however - check that the old switch looks like the new one! Very often if you remove the switch form the A-post you can clean up and improve the existing one, they are very low-tech (the lowness of the tech is matched only by the lowness of the quality!). Often too it is the earth connection (provided by the self-tapper holding the switch in place) which is the problem. I find that my door switches all benefit from periodic servicing to clean them and keep them working. |
drivers side door actuator
FUD500020 Last edited by dorsetsmith on 28th Jun 2021 10:57am. Edited 1 time in total |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
Actuator or door switch?
Door switch: AFU4241L https://www.lrworkshop.com/diagrams/land-r...9976_52873 Actuator: FUD500020 https://www.lrworkshop.com/diagrams/land-r...7_52671#30 > 110 XS Double Cab |
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 ![]() ![]() ![]() |
Thank you for the link it is the actuator I'm looking for.
Andy Defender Td5 XS90 |
Ah, sorry, I saw "alarm" and "door" and made the wrong assumption! My bad!
