Home > Puma (Tdci) > Oil in engine bay and bonnet
Silver110
England 2008 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Hi all,
Just had a trip up to Lake District and back from the south coast. About 50 miles from home started to hear a slight metallic noise every now and then apart from that no issues.
Got home abs opened the bonnet to find the below. Does anyone have any ideas on what they think this could be?
TIA
[/i]
Post #908958 22nd Jun 2021 3:34pm
landy andy
Vacuum pump failed. Think it’s a known issue although thought they had all failed by now.
Post #908962 22nd Jun 2021 3:56pm
landy andy
Post #908964 22nd Jun 2021 4:01pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
landy andy wrote:
… thought they had all failed by now.
Laughing Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #908966 22nd Jun 2021 4:22pm
hank
Having recently replaced my brake servo vacuum hose I came to realise that the sole purpose of the vacuum pump is provision of vacuum for the brake servo...
What I don't understand is why the vacuum pump is required at all? Why does the servo not take vacuum from the engine inlet like conventional vehicles? Of course after after the turbo the system is under pressure, but could vacuum not be drawn pre turbo?
Obviously the answer is no else there would be no requirement for a vacuum pump! Just curious for my own understanding Thumbs Up > 110 XS Double Cab
Post #908970 22nd Jun 2021 5:33pm
Dinnu
For petrol engines yes, because petrol need to control the air to maintain the air/fuel ratio. Controlling air flow creates vacuum at inlet.
On a diesel, the air/fuel ratio is not important, and so there is no need to control air, and hence no vacuum at inlet (unless filter is seriously blocked). Having said that, modern diesels have something similar to petrol throttle body, but that is related to emissions control (and helps in smooth shutting down of the engine - no air, no compression). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #908972 22nd Jun 2021 5:54pm
Bluest
Diesels don't produce enough vaccim as they are unthrottled. Some more modern diesels do have a throttle, but I don't know if that does away with the need for a pump. 2007 110 TDCi Station Wagon XS
Post #908973 22nd Jun 2021 5:55pm
hank
I see, thanks! > 110 XS Double Cab
Post #909069 23rd Jun 2021 11:19am
