Home > Maintenance & Modifications > UZ-FE3 conversion
Timbo
England 2008 Defender 110 V8 Petrol USW Tonga Green
UZ-FE3 conversion
Hi This is my first post, only just joined, so forgive me if this topic has been covered before but I can't find the answers anywhere. I own a 2008 TDCI and have recently bought a lexus ls430 with the 3UZ-FE engine with a view to putting it in my defender. I can't find an adaptor plate to keep the existing manual gearbox. Is there anybody out there who can tell me if there is one? Failing that I can find a plate that converts it to a BMW gearbox. I understand the MT82 gearbox is made under license from BMW so can I get a BMW bell housing (which also has an outside slave cylinder) and bolt it to the MT82 gearbox? Does anyone know if the bolt pattern is the same? Any help or advice regarding all aspests of this conversion would also be gratefully recieved. All the best Tim
Post #908030 15th Jun 2021 9:14pm
Timbo
I now realise the stupidity of my initial question as the bellhousing is not take offable. Has anyone done the 1 uz-fe or 3 uz-fe conversion with an m57 manual gearbox to the lt 230 transfer box? If so any advice would be greatfully received. I can get a conversion plate to m57 gearbox but I'm finding it hard to get an M57 gearbox. Are there any conversion plates from lexus engine to an equally strong gearbox that any one has tried? Any help would be super as I think the head gasket has gone on the tdci so I may need to tackle conversion sooner rather than later Big Cry
Post #913917 24th Jul 2021 10:04pm
I'm not aware of any connection between BMW and the Ford/Getrag MT82 transmission.
Post #913921 24th Jul 2021 10:53pm
Co1
I know this is for a 300tdi, but gives these guys a ring and they may well be able to sort you out:
https://www.onlinegearboxparts.com/product...-flywheel/
Post #913944 25th Jul 2021 8:19am
sako243
I've got one of the Synchrogearboxes adapter kits (1UZ to 300Tdi) which doesn't fit my donor engine very well - I could have the flywheel bored out but thinking of keeping the original auto box now so if you wanted one it's available. Already got the ring gear mounted on the flywheel. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #913954 25th Jul 2021 9:37am
LR90XS2011
there are a few on Instagram doing these types of conversions and adapters DEFENDER 90 TDCI XS,
Post #913957 25th Jul 2021 9:58am
Timbo
I'm now resigned to the fact the mt82 transmission has to go. With it's internal slave cylinder I'm not going to miss it but I'm looking now for a conversion plate from 3UZ-FE engine to an M57 gearbox as I know there is also an adaptor plate from M57 gearbox to lt230 transfer box. I was however looking to see if anybody has an adaptor plate from 3 UZ-FE engine to an equally strong gearbox other than an M57 as these seem hard to find Big Cry
Post #914027 25th Jul 2021 9:43pm
Timbo
Thank you Yes I asked them the question regarding a plate and they advised the M57 gearbox as they do an adaptor from that to lt230. It's the gearbox I'm struggling to find as drifters use them apparently Rolling Eyes
Post #914028 25th Jul 2021 9:47pm
Timbo
I wanted to send you a PM but as a newbie computer said no!! I have in mind the PMC adaptor from 1/3 UZ-Fe as they are apparently the same at the back to M57 gear box I did however think last week why don't I put the R380 gear box on then that'll bolt straight into LT230 Idea I don't know if anyone has done this but I'm also not sure if it is a strong enough gearbox. I need to join instagram as apparently there are people that have done it. Thumbs Up
Post #914029 25th Jul 2021 9:56pm
Timbo
Thank you will give it a try as I'm not on instagram at the moment Shocked Laughing
Post #914030 25th Jul 2021 9:58pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I have done the 3UZ with R380 https://www.defender2.net/forum/topic73015.html
If you want a manual then you're best off with the GS6-53DZ out of many many BMW's. There are plenty available from ebay or breakers. There is an engine and transfer adapter for this transmission. 1989 90 4.3 V8
2012 L405 OF
2014 D4 HSE Lux (SOLD)
2015 90 HT (SOLD)
@d9o.mf
Post #914050 26th Jul 2021 8:42am
sako243
Torque is what tends to kill gearboxes - particularly the lumpy instantaneous torque of 4 cylinder diesels. If you look at the torque profile of a 300Tdi vs. say a 4.6V8 the peak torque of the 300Tdi as each cylinder fires is significantly higher than that of the smoother running V8. So although the 1/3UZ might output more torque on paper that doesn't tell the full story. The R380 and LT230 is a simple solution - provided you're not a lunatic I don't see why it wouldn't work and there's a simple adapter plate off the shelf (and conveniently the one I have surplus to requirements Whistle).
The one thing that is bloody tight is the passenger side header to the clutch slave cylinder. Ed
Post #914053 26th Jul 2021 9:02am
Timbo
I just took a quick look at your thread and it's impressive to say the least! I'm pretty sure I'll be delving into it many times from now on. Re the GS6-53dz there are lots about but apparently its the 330 or 530 variant with codes HGU and HGD that fit the PMC plate unless you know to another adaptor plate maker, in which case please let me know. The majority of the gearboxs on ebay are N47 with a different bolt pattern to M57. Thanks for the reply and I'm pretty sure I'll be asking you lots more questions Rolling with laughter Big Cry
Post #914161 26th Jul 2021 9:28pm
Timbo
Well I am a lunatic which is why I'm putting a V8 lexus into my land rover with very little experience and knowledge and a lot of enthusiasm. Rolling with laughter I may very well take up your offer of a plate. I'm in conversation with someone at the moment regarding procuring the M57 gearbox so if this doesn't come off I'll be in touch. I think I've done enough post's now to send a PM Very Happy Thank you for the reply will be in touch Thumbs Up
Post #914166 26th Jul 2021 9:37pm
sako243
Best way of learning.
Rather than trying to do everything in one hit why not try the R380 route first since it's a simpler, if the box doesn't survive / you don't get on with it then can always look for upgrades. Ed
Post #914198 27th Jul 2021 8:15am
