Home > Puma (Tdci) > Handbrake adjustment.
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
Can someone please indicate where the adjuster is on the handbrake housing. I'm assuming it's on the non rotating side facing the Transfer Unit but I can't spot it. "You are never to old to learn something new"
Post #906520 4th Jun 2021 11:54pm
The adjusted is at the bottom of the front face of the handbrake backplate and takes a 17mm ring spanner.
Post #906521 5th Jun 2021 1:48am
dorsetsmith
Post #906543 5th Jun 2021 10:56am
B4Lamb
Thank you both.
The adjuster is where you say. It's indented and not that easy to spot as it was covered in black build up of dust and grease. I'm having to adjust the cable as well as It's stretched. Adjusting that is a lot harder as you need thin arms and two open ended spanners (17 mm and 22 mm). What a nightmare doing it up there blind!! "You are never to old to learn something new"
Post #906555 5th Jun 2021 2:03pm
