Home > Maintenance & Modifications > Removing powder coating from a galv part.
Bluest
How would you this if you wanted to leave the galv in tact? Will a blasting process remove the coating without going through? 2007 110 TDCi Station Wagon XS
Post #906125 2nd Jun 2021 11:03am
rallysteve
The not eco-friendly method is just to melt it off with a blowtorch Whistle
You can get poweder coat strippers but the good ones dont seem to be available in europe. Depending on the type of powder coating you have you could try a bit of petrol or brake fluid.
Post #906128 2nd Jun 2021 11:12am
I would use a nylon paint removal disk for a grinder, stop as soon as you see the surface and of course you’d need PPE. That should do most surfaces and uses a Dremel or similar item for the corners.
Galv is tough stuff as long as you don’t use really coarse abrasives.
The nylon stripping disks should help.
This is why I don’t like powder coat, it’s more trouble than it’s worth. I’d rather have paint and thin PC over mild steel is just…. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #906144 2nd Jun 2021 2:04pm
Wait for a while and it will fall off by itself!
Sorry, not helpful. Sad
Post #906150 2nd Jun 2021 3:00pm
jimbo55
Depending on what the item is, either jet washing it holding the nozzle near enough on the part. Once you’ve got a bit to lift off then you can normally chip away at it quite easily
or if not then burning it off as Steve already said
Post #906158 2nd Jun 2021 3:56pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Steve
I’m part way into a MSS locker renovation and have just done what Steve suggests - melt it off. I used a cheap n cheerful butane canister torch and scraped with a woodwork shavehook. Additional hassle due to previous owner overpainting with thick coats of hammerite.
Post #906170 2nd Jun 2021 5:58pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
If you know someone with a pyrolysis oven that will keep the temperature below the melting point of zinc say 350C that should reduce most powder coatings to an ash that should just brush off. We used this technique on some coatings when I was working.
Post #906180 2nd Jun 2021 6:39pm
MichaelE
Buy a new/replacement part that isn't powder coated.
Post #906222 2nd Jun 2021 9:37pm
Bluest
Thanks all. I think hearing/burning it off might be the way forward. 2007 110 TDCi Station Wagon XS
Post #906226 2nd Jun 2021 10:02pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Just be mindful that using a heat source on the galvanised zinc coating could give off dangerous/toxic gasses Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #906246 3rd Jun 2021 5:32am
Bluest
Outdoors on a breezy day it is then Laughing 2007 110 TDCi Station Wagon XS
Post #906258 3rd Jun 2021 7:14am
Matt110
I need to do this with my safari equipe tree sliders, so watching with interest!! Can you share how you got on when you do it? Thumbs Up
I was originally going to rub down but worried about going through the galv, and would really like to keep them galvanised given the abuse they get.
Post #906272 3rd Jun 2021 8:43am
When some miserable lowlife type poured patio cleaner over my bonnet and wings it was extremely effective at removing the powder coat from the Nakatanega RAI wing plate. Given that Nak powder coat seems to be an order of magnitude better than any other powder coat I have met on aftermarket LR products, I imagine that it might be very effective as a general powder coat remover. Just be aware that it isn't good for paintwork though, and I don't know if it would discolour the galv in the way an etch primer does.
It might be worth a try on a gash part or out of sight area though.
Post #906275 3rd Jun 2021 8:53am
Bluest
I about to order a set of Safari Equip tree sliders today, although that wasn’t the reason for starting this thread. Rolling with laughter 2007 110 TDCi Station Wagon XS
Post #906278 3rd Jun 2021 9:14am
Matt110
Don't be put off..... they're fantastic products. They're superbly robust, and have hit many trees on my 110. Great product. Mine are about 5 years old, and the coating is really only now getting to the point whereby it's looking tatty and needs some help, and has adhered well given it's over galv.
Just that its always been non-matching coating to my cage, and i'm a tad OCD and want to make it look nice again and get rid of the bits where the coating has flaked off.
For what they've achieved - it's absolutely fine in coating terms Thumbs Up
Fitting them is hard work, but worthwhile. Make sure you space them down at the front so they dont touch the bodywork or you'll end up with wing corrosion.
Post #906293 3rd Jun 2021 10:42am
