Home > Maintenance & Modifications > 4 Point Harness with Roll Bar? |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
Anyone fitted 4 point harness in the defender? I’ve got a safety devices internal hoop over the front two seats I’d like to utilize. Curious what it would take and how they are set up. I don’t know much. I have seen them on safety devices website. Thanks
I’m considering this but have no idea how it would install https://shop.safetydevices.com/collections...ht-harness |
30th May 2021 9:08pm |
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 512 |
Thought about it myself. Basically, unless you're willing to no longer having functional or safe rear seats then it's a no. You either need to install them to a bar directly behind the seats like so
Click image to enlarge Or, to the seat mounts of the rear seats Click image to enlarge You cannot mount them to the floor directly below. In a crash or impact the straps will tighten downwards crushing your spine. There are very strict FIA guidelines on it that give exact angles if you're interested Stuart Cummins 130 Build Thread 04 110 Double Cab - Black (gone) 58 130 Double Cab HCPU - Cairns Blue |
31st May 2021 10:52am |
