Home > Maintenance & Modifications > MSS rear quarter light window guard fitting - help please |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
30th May 2021 5:45pm |
Fellrunner Member Since: 28 Sep 2014 Location: Wandering Posts: 255 |
Thanks Chris. I’ve got those, but they don’t help (I understand the instructions), it’s the bracket design which seems to be wrong (I’m wondering if I may have been sent the guards for an earlier model year and thus perhaps different bolt spacing).
30th May 2021 5:51pm |
PlumberBoy Member Since: 01 Sep 2020 Location: Hertfordshire Posts: 4 |
Hi Fellrunner
Ive just got these guards & got same issues as yourself. What was the outcome of this post ? Cheers Jon |
13th Jul 2021 3:40pm |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 985 |
Not sure if anyone else found a better solution, but I just used a hacksaw and BFI.
13th Jul 2021 4:09pm |
I shall be returning them if they not correct. As they cost & if not engineered correctly.
13th Jul 2021 4:26pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4401 |
Hey folks I have had these fitted to my 110 for 8 years or so now. Happy to pop out and get some photos for you...
I do recall the instructions being terrible with this kit. |
Its nothing to do with instructions, the brackets are not correct for bolts. My Defender is a 2009
13th Jul 2021 4:50pm |
Ah ok. Well here are the guards fitted to my 110… hope they help…
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
13th Jul 2021 5:47pm |
Hi Geobloke
I can see from your pic the bolt positions & bolt type are different to ours. It appears the guard brackets are correct for your year of Defender. Ive sussed it out now..these guards do not fit a Puma Defender with seat belts. As the reinforcing bracket for the belts is in the way & also creates different bolt positions. The guards are too large & bolt holes incorrect. |
13th Jul 2021 6:33pm |
So I contacted MSS and was told that the design of the guard hasn’t changed; there’s only one version available and it’s down to the individual to modify to fit their particular Defender.
5th Aug 2021 9:01am |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 149 |
It seems that most upgrades require some modification of the new component, or the vehicle, usually both, together with some additional components that you have to buy or fabricate yourself.
Sometimes it's half the fun, sometimes it's a ****** nuisance, and not easy to predict which in advance. |
5th Aug 2021 1:37pm |
