Home > Td5 > TD5 Rear Door Latch with central locking |
Did they have central locking on the back door before 2002? I thought that came in with the change to the pressed steel door. Darren
17th May 2021 11:27am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
I think you’re right. My central locking looks an aftermarket affair.
The rear lock has a hole drilled underneath and the rod to actuate the lock is routed from below. The latch/lock itself is worn and won’t stay locked (although it closes ok, a good push on the lever will unlock it even if it’s meant to be locked). I might just have to replace with a normal latch and live without central locking on the rear door. Cheers Simon |
17th May 2021 12:08pm |
