![]() | Home > Puma (Tdci) > Puma video build |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1490 ![]() ![]() ![]() |
Sorry to continue taking this thread off topic.
The quality of the adapter shaft is remarkably consistent. How else could you explain 4 failures in the same vehicle, all at around 25,000 mile intervals? The owner would have been very unlucky to get 4 bad shafts in a row, over a 7 year period. During that time shafts have been running in other vehicles for over 100,000 miles, sometimes well past that. Variable shaft quality would result in large variance of failure intervals in the same vehicle. This is not seen in the forum survey on the topic. The survey does show that if you continue fitting standard shafts, without changing anything else, then they all fail at roughly the same milage interval in a vehicle that has the problem. Back on topic. Thanks to Nigel for continuing to post his every interesting and informative videos on the comprehensive rebuild of his 90. ![]() |
Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114 ![]() ![]() ![]() |
Back onto the subject,
I am just uploading the 4th part of the engine reassembly with the fitting of Piston cooling jets and the gallery filter below No1 main bearing, neither of which are mentioned in the build sequence in the manual? We also get the crank in and I discuss the need for stoning of mating surfaces during assembly. I will make a new video regarding the alignment of transfer case to MT82 today. Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
I have since altered my opinion on this matter and will make a video discussing this later today. Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3749 ![]() ![]() ![]() |
I’m famous!! I’m famous!!
Just watched the latest vid nige, thanks for the shout out! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
Interesting video, what you describe is exactly the conclusion I came to. It is going to be extraordinarily difficult to measure though.
Incidentally the reason I don't comment on your videos on YouTube (or anyone else's for that matter) is that you cannot comment unless you have a YouTube account. I don't, and don't want one. I am also of the view, and I say this with the greatest respect and no intended criticism, that if someone promotes their videos on the Internet's best Defender forum, it is only to be expected that comments are made and discussions take place about said videos on the forum. Last edited by blackwolf on 17th May 2021 8:33am. Edited 1 time in total |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
I only put forward the quality of manufacture as a question and its obviously not that so if its alignment issues do people think the lof one piece solution will end up with more expensive gearbox problems down the line..i really dont know how you would be able to separate normal gearbox failure from lof induced failure........ |
Latest video is great Nige. “Health and safety wise it’s a no no, so don’t tell anybody I told you!”
Why is it a H+S No no? Nige
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
I think a lot is down to driving styles causing this. Especially the way individuals change gear. The difference in fully pressing the clutch down and pausing after you engage the next gear to allow everything to torque back up at low revs before gradually introducing the power vs quick gear changes with a partially depressed clutch and pushing the accelerator instantly back down as many do in modern cars. My style is akin to driving classic and vintage cars. Not intentional abuse but over thousands of gear changes the spinning up of the play in the drive chain I'm guessing adds up. I may be toitally wrong.... |
I was you that said it was on the vid! You were talking about the virtues of using a screw driver to the ear to check for tappets knocking with the engine running and rocker cover removed. |
Hahaha Co1.
I forgot that part.. I thought you might be referring to my lashed up engine stand? Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
[quote="DSC-off"]Sorry to continue taking this thread off topic.
The quality of the adapter shaft is remarkably consistent. How else could you explain 4 failures in the same vehicle, all at around 25,000 mile intervals? The owner would have been very unlucky to get 4 bad shafts in a row, over a 7 year period. During that time shafts have been running in other vehicles for over 100,000 miles, sometimes well past that. Variable shaft quality would result in large variance of failure intervals in the same vehicle. This is not seen in the forum survey on the topic. The survey does show that if you continue fitting standard shafts, without changing anything else, then they all fail at roughly the same milage interval in a vehicle that has the problem. It would of been interesting if a lof one piece was put into that sort of truck you mention to see what happened! perhaps somebody on here has done that? |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Not intentional abuse but over thousands of gear changes the spinning up of the play in the drive chain I'm guessing adds up. I may be toitally wrong....[/quote] I’m with you on that one. /\ /\ |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
Nice to see your truck coming together Nige
