Home > Td5 > Td5 Defender ABS Problems - Continued
bankz5152
This has been an on going issue for around a year now.
ABS/TC light on, started intermittent and could be reset. However now its constant
Nancom states front right sensor intermittent.
Changed the sensor with a Britpart G sensor. (Changed the sensor 6 / 7 times before now)
Resolved the issue for about 6 months
Lights back on Crying or Very sad
So changed the shuttle switch today for a Wabco unit, (only took 5 hours Shocked) also added the wires for the wiring mod should it be required. Just not 100% whch wire to tap into. D2 is yellow/green not present on the Defender, apparently it could be pin 9 black/red?
Cleared the codes, test drive. All ok for a couple miles then the lights come back on!! Evil or Very Mad At least it is now intermittent again not constant!
Also one very concerning thing is when braking lightly the TC will kick in and try and pull me right.
Next step is the change the CV Joint. After that im at a loss, any suggestions?
Driving me bloody mental
Post #900949 1st May 2021 9:03pm
4RF RDS
If after you change the valve and you still get the same codes you likely need to change the intermediate valve block as well Big Cry
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #901197 3rd May 2021 4:27pm
