Home > Puma (Tdci) > Lof half shafts
Ijk10
Wales 2007 Defender 110 Puma 2.4 CSW Keswick Green
Lof half shafts
Hi all
I'm fitting some lof half shafts on the weekend. When installing do I have to put grease on the spline? Any tips would be appreciated.
Post #900508 29th Apr 2021 10:48am
Bluest
Assuming the one piece ones, then no, they go into the axle oil. Maybe given a smear of gear oil so they aren’t going in dry, so to speak, but it’s probably not critical. 2007 110 TDCi Station Wagon XS
Post #900510 29th Apr 2021 11:23am
Ijk10
Thanks buddy...thats great. Will I need to top up the oil or not much will be lost. They are the one piece shafts.
Post #900516 29th Apr 2021 11:45am
Bluest
Just jack up the end you are working on and you shouldn’t lose much or any at all. 2007 110 TDCi Station Wagon XS
Post #900518 29th Apr 2021 11:48am
Ijk10
Thanks so much👍👍
Post #900524 29th Apr 2021 12:05pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
I smeared some diff oil over the splines and then down the shaft where the bearing sits.
I had some spare, so thought I might as well, but probably not crucial.
Although it is worthwhile putting some on the paper gasket to hold it in place, but guess you could use any old oil for that. 2011 CSW XS 90
Post #900526 29th Apr 2021 12:17pm
jst
or grease the gasket and then its can be reused too Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #900619 29th Apr 2021 9:22pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Good to hear that these are straightforward to fit.
I've only had my defender a week or so, and the clunk taking up drive is driving me nuts. So I'll start with these and then see what else is needed!
Post #900665 30th Apr 2021 9:31am
SJM2018
You'll likely just start hearing other clunks Laughing
I did mine, but now can hear a different 'smaller / lighter' clunk from underneath.
Suspect it could be the output shaft, which I'll change to the upgraded LOF version, when I fit their clutch bundle in the coming months. 2011 CSW XS 90
Post #900684 30th Apr 2021 10:45am
jpboost
Yes you're probably right.
A good friend of mine's output shaft failed completely so I'm aware that it's something I'll probably need to do.
I've been reading up on the ashcroft kit as well as the LOF one. I've not made any decisions yet, but I'm sure either of them will be 'fit and forget' in real terms. I don't do huge mileage anyway.
I'll check the front drive flanges and propshafts too, as I understand they generate similar clunks (although less severe).
Post #900706 30th Apr 2021 12:48pm
Ijk10
All done this morning
So much better now. The longer shaft didn't have any play but the shorter side was real bad...
New lof clutch and output shaftin two weeks should make the drive even better....
Post #900882 1st May 2021 3:11pm
