Home > Maintenance & Modifications > 12s plug advice
Griff90bowler
Wales
12s plug advice
Hi guys I have a 12s kit left over from my 07 puma that I never fitted LR005921 I’m fitting it to my MY15 puma but there seem to be some differences there is no 12s plug in the rear wheel arch just a big grey multi has anyone had this they could help with the mod
Post #899556 22nd Apr 2021 3:53pm
Martin
Site Admin
https://www.defender2.net/forum/topic2573.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #899564 22nd Apr 2021 4:14pm
I'm not quite sure what you're expecting to find in the wheel arch, but the big grey plug (for the standard 12N connection) is the only thing provided on my '07 Defender. The 12S kit as I recall has more complex wiring to various point on the vehicle, including the need for an ignition-on, relay controlled feed from the dash area.
There is no 12S connector, as such, only the 12N.
Post #899570 22nd Apr 2021 4:34pm
Griff90bowler
Wales
There should be a plug off the back of the 12n loom to plug the 12s into but can’t find anything other than a big purple wire with no pin in the grey multi plug
Post #899578 22nd Apr 2021 4:51pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hello Griff,
The purple wire is the permanent 12v supply, fused I think at 20amps. Thai should be part of the car loom and continue through the 12s wiring loom.
All other spare 12s wires need wiring into the vehicle by you. The white wires, with or without marker colour should be earths. Then the wires going to pins 9 & 10, need to go to the battery box, and connected to permanent live, and ignition live respectively, although, on a kit I’ve installed, the purple wire does go through the grey plug, to give this permanent live.
Here are the full installation instructions for the Bearmach kit.
https://www.pfjones.co.uk/pfjoneswiringkit..._01-99.pdf
Hope this all makes sense to you,
Ashbyandy 👍
Post #899685 23rd Apr 2021 9:23am
Ashbyandy
Sorry Griff,
I’ve shown you the wiring for the 13 pin. If you are wiring 12s, alongside your 12n, then all wiring will need to be extended by yourself. There is no 12s socket in the vehicle wiring loom. The purple wire though is still permanent 12v, and can be used,
Ashbyandy
Ps, all as stated y Blackwolf in above post
Post #899690 23rd Apr 2021 9:33am
