![]() | Home > For Sale & Wanted > [Wanted] Now Sorted ....A couple of PTO bits |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 153 ![]() ![]() |
![]() Click image to enlarge I've just stripped and rebuilt my Superwinch PTO .... Does anyone have tucked away in a deep dark corner, the red plastic cover that keeps all the ![]() Also, a long shot I know, the adaptor to set the torque. Cheers Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
Now sorted thanks to Darthdicky
![]() ![]() Click image to enlarge Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
darthdicky Member Since: 02 Jul 2011 Location: Newton Abbot Posts: 78 ![]() ![]() |
Meant to say, I never had a torque adaptor for mine but I did spot them available here: https://www.lr-winches.com/Parts/Power_Tak...que_Adaper
Also, if anyone wants a broken PTO or spare clutch mechanism I have one of those too. Complete (apart from the red cover) but the casing split in two after I hit it on a treestump. Would highly recommend fitting a bash plate if you're going to be using it off road! |
Cheers, I have seen them.on that site, he also has them.on eBay.
But as necessity is the mother of invention I used the UJ with the sliding joint, worked a treat. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge So pop everything back where it belongs and its onto rebuilding the tub ![]() Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
