Home > Maintenance & Modifications > Scratch Removal Advice Please
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I enjoyed a fantastic day on Salisbury Plain, it felt so good to finally be able to escape the house! Very Happy
Along the way I picked up some scratches to my usually pristine firenze red body work on my puma 110.
Does anyone have any recommendations on the best products / tools to help be rid of them?
Post #899266 21st Apr 2021 7:36am
Matt110
Does depend on the depth of the scratch as to what to recommend, have you got any photos or can you tell if they're only surface lacquer scratches?
Post #899277 21st Apr 2021 8:43am
Clemmo
As stated above..
It depends on
Depth of scratch
Type of finish.. ie solid colour or lacquer coat?
Very minor scratches will hide with T- cut or similar.
Slightly heavier scratches use Farecla G3.
Both products use by hand.
A body shop is the next step...unless you want to try machine polishing yourself.
Clemmo👍
Post #899279 21st Apr 2021 9:10am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
If you rub a wet finger over the scratch and it disappears normally it will only need a light finesse cut back, anything deeper really depends on the severity of it.
Will they show in a photo? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #899299 21st Apr 2021 10:52am
JPE
Thanks for the advice, I'll look into those products. I washed it to get all (well some) of the Salisbury mud off & I couldn't see the scratches when it was wet, which I'm taking to be a good sign that they are not so deep. Thanks again.
Post #899364 21st Apr 2021 6:12pm
Personally I’d not go any more course than Farecla G10 unless experienced, and then up to polish. Go with the lightest possible first the clear is not very thick so be very careful.
It is however quite hard which is a good thing, at least on mine it is but you don’t have much thickness to play with.
From what you’ve said a basic standard polish should work. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #899365 21st Apr 2021 6:17pm
markb110
Once you have had your first 50 scratches you stop worrying about them, even more so when you get the mother of all scratches down one side that means all the others just melt away...... Whistle
This was 'collected' on the lane to Salisbury Race Course.
Added benefit is that you can pull out in front of leased BMW'S and Mercedes and nobody wants to park next to you...win win Laughing
Post #899376 21st Apr 2021 7:49pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
^^^^ This is the 'correct' finish for a real Landrover Thumbs Up
Post #899425 21st Apr 2021 10:26pm
spudfan
Ireland
""Go faster stripe?" Whistle 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #899551 22nd Apr 2021 3:40pm
Matt110
There was me hoping Salisbury would be fairly non-scratchy!!!
Post #899555 22nd Apr 2021 3:52pm
markb110
99.9 % of the Plain is fine, go and enjoy.
The lane on the day runs from just south of Salisbury to the racecourse.
It fact the last time I was there it was narrower and lower than the Defender.. As councils aren’t clearing lanes it is down to vehicle use to keep them open. It’s all to easy for the councils to do nothing and then down grade a lane.
Unfortunately with thinking like this the overgrowth also hinders horse riders, cyclists and other users. Evil or Very Mad
Post #899563 22nd Apr 2021 4:13pm
