|  | Home > Puma (Tdci) > Header tank - seam is failing |
| Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84      | I had exactly the same issues, I fitted a Britpart one (I'm not generally a fan of Britpart). I guess its been on 6 months now and so far no issue. I've done a lot of off-road snow driving and some long motorway drives with it. | ||
|  19th Apr 2021 5:53am |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3656      | Thank you Kevlar. I would not be surprised if Britpart sources the header tank from OEM.
 Good to hear that yours is good.  I might have to go down that route. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black | ||
|  19th Apr 2021 8:01am |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2556    | If you want to push the boat out and spend a fair bit of cash https://www.optimill-uk.com/defender-tdci-header-tank.html then optimill do an aluminium one. But it does come in at £270 !!!!!  Compared to circa £30 for a Britpart one , £44 for a bearmach one or £70 from landrover. I’m sure I’ve seen some forum posts on it. | ||
|  19th Apr 2021 11:19am |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2708      | Is it gold plated for that price.....   | ||
|  19th Apr 2021 12:08pm |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3656      |  £270  I am sure that I do not want to pay that money, plus want to keep it stock. It it was not for the stock look that I want, there are a lot of options, aluminium or plastic, although I do not know what is the effect of introducing another metal in the cooling circuit. I guess it will not be exact alloy as the head! Since the genuine one failed at about 8 years, I think I will not go that wrong with a britpart or bearmach one. Would be nice to have a level sensor for worse case.. probably a capacitive sensor and an alarm, stand alone would work. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black | ||
|  19th Apr 2021 12:10pm |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2556    | To be honest I would seriously struggle to justify £270. One additional cost I would think about is adding the
 IVECO 99489567 Cap mod. See https://www.defender2.net/forum/topic44373...oolant+cap | ||
|  19th Apr 2021 12:48pm |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3656      | I read it is somewhere that the LandRover cap is crap but I could not find the thread. Thank for that    1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black | ||
|  19th Apr 2021 7:06pm |
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 831      |
 Any difference between the Optimill tank and the AlliSport tank? | ||
|  20th Apr 2021 3:20am |
| andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617      | the caps  are prone to fail  mines on its third      | ||
|  20th Apr 2021 11:33am |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | The tank  plastic is  also   prone  failing  had  this problem on 53 plate  90  replaced tank with new one and    looked at old one only to find bottle neck out shape so  cap will not sit flat look at the bottle before replacing with caps | ||
|  20th Apr 2021 11:47am |
| Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781      |
 No - they are both too expensive!. Rgds. Chris | ||
|  20th Apr 2021 11:56am |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2556    | ^^^^^^^^^^
 The allisport one seems to have a couple of options, like sight glass and float level switch. But theses are expensive items that may justify themselves if you need absolute reliability in extreme conditions but beyond that the standard LR one seems to perform ok and you can get 3 or four of them for the price of the aluminium ones. As for checking fluid level I do when cold by dipping my index finger in, which seems to be the perfect length. | ||
|  20th Apr 2021 12:11pm |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3656      | I put a flash light against the tank (bottom side) and it shows the level quite clearly. Every phone has a flashlight nowadays. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
|  20th Apr 2021 12:40pm |
| llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151    | Try Paddock Spares
 https://www.paddockspares.com/pcf101530-ex...-puma.html I have had one a while now - no issues yet | ||
|  20th Apr 2021 2:21pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
