![]() | Home > Technical > Never too old to learn.... eh? |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 833 ![]() ![]() |
Welcome to the forum.
Post up some pictures of your 90 for us to see. ![]() ![]() |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673 ![]() ![]() ![]() |
Welcome
Start with the basics. Open the fuse compartment in front of the gear stick and push all of the fuses to ensure that they are fully pushed in. Hopefully this simple solution works for you. ![]() |
Vera's Driver Member Since: 26 Mar 2021 Location: Oxfordshire Posts: 19 ![]() ![]() |
Fuses all checked and appear well embedded. Should it happen again I'll take the time to follow the green, green brown, purple , white, etc , etc
![]() Next post I'll make sure is in the right topic area ![]() |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
its what is known as french electrics
![]() No disrespect to our french lads, ( french electrics came from the 306 forum ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
It usuall.y comes back to poor earth connections. Jeff
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
Agree - hazard unit, radio and clock all share a common earth point on a TD5. JB
@Lodelaner Instagram Youtube greenlaning and other LR related content |
Honestly you are on a fabulous LR journey, plus the TD5 is a super engine for the DIYer. Don't fear the electrics they're not that tricky. First job, as others have said is to go around and clean up your major earth points, see plan: ![]() Click image to enlarge All you need are a wire brush, scrap of wet n dry and some electrical grease to refit and protect it all. Good first project... Shout out if you need help and if you are planning on keeping the 90 for a while think about saving up for a nanocom... Blinkin' great piece of diagnostic gear and worth every penny IMHO. There is usually a group buy going on someplace. |
Vera for me is for life. love her to bits already. Got the Missus driving her around Oxfordshire and we both agree , worth investing in the fun and unpredictability . Will seek those earthing points. It’s a matter of deduction... isn’t it
![]() Last advice. Side windows rattle and note there are no brush inserts. What are these actually called? Look at some websites such as Bearmach and Rimmer Bros , but these inserts don’t seem to be itemised. Are they? it’s me or are they called something a little more technical? |
Think they’re called felts.
https://rimmerbros.com/Item--i-MWC7620 Rattling rear windows are a perennial issue. If they’re not rattling your windows have fallen out! JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
Cheers Lodelaner
After days of checking earthing points and connections etc. ,finally located the problem . Hidden in a location not as per diagrams was blue connector 0287 (K109). Cannot get to it without removing lower dash, but giving it a tap makes the hazards, radio, internal lights and clock come back on again. Imminent weekend project to permanently rectify the fault . So good to find the cause. Thanks to all the advice offered.
