Home > Maintenance & Modifications > Defender Heated seats element OEM |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3615 |
If you get non OEM ones, Martin on here will sell the OEM plugs and a bit of flex for you to joint in. The OEM pads are about 3 times the price of non OEM.
14th Apr 2021 6:35pm |
90GTR Member Since: 05 May 2020 Location: London Posts: 198 |
Thank you and noted if it applies again or the below doesn't materialize....
In my eagerness to get the solution solved, I bought the exmoor trims full kits for the pair and I'm assured they're in stock... circa £115. |
14th Apr 2021 9:22pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19560 |
Waeco are good, I use them and you can use them with factory switches just identify the pre heat wires and not use those those and just use the standard heat setting wires.
That’s what I did, I’ve heard the Waeco ones are warmer that factory but can’t comment myself. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Apr 2021 9:52pm |
