Home > Technical > Fault code P101 |
The MAF sensor is very easy to access as it's attached to the outlet pipe on the lid of the airbox. It's secured by one small Torx bolt:
Click image to enlarge If that's what the fault code says then it's worth giving it a clean as a first step to see if that makes any difference. It's also worth checking the condition of the wiring to it as they have a habit of fraying due to the long, unrestrained cable to it: Click image to enlarge If the wiring is damaged then you can buy repair sections from the site shop and details of how to fix it can be found here: https://www.defender2.net/forum/post853238.html#853238 If you do need a new sensor then the part number is LR019830. A genuine part from Land Rover is around £170 but you can buy OEM quality replacements for under £70 from the likes of Island 4x4: https://www.island-4x4.co.uk/flow-mass-sen...-8185.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 13th Apr 2021 9:03am. Edited 1 time in total |
13th Apr 2021 8:10am |
Jocee458 Member Since: 12 Apr 2021 Location: Midlands Posts: 3 |
Hi,
Thanks for the reply. Guess what hubby will be doing over the next few days. 😳😊 |
13th Apr 2021 9:01am |
Lucky him Darren
13th Apr 2021 9:04am |
Hi. Just thought I’d update you. So we (my husband) 🤪😂😂 changed the mass air sensor and the light was still on. He then checked all the hoses and found a split in one. Temporary repair and light now off. 😊😊😊 Happy days. Thanks for your help.
22nd Apr 2021 10:09am |
