Home > Maintenance & Modifications > Those with Thermotop C, in use experiences |
drakes Member Since: 09 Oct 2009 Location: Hexham Posts: 111 |
In short yes. I find if using the preheat then the glowplug light goes straight out but as you say the temp gauge does not get to normal temp from the thermo top alone.
11th Apr 2021 4:03pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
Depends on ambient temp, whether the heater control is set to hot/cold, whether the fan is engaged and the run time.
It was 3 degrees here this morning, the heather control was set to hot, the fan was off and it had been running about 30 mins. The temp gauge indicated that it was about 2/3 operating temp when I started the engine. The temp then dropped to 1/3 operating temp (presumably as the cold oil cools the engine / I put the fan on to warm the cab), but recovered and was at op temp a little over 10 mins after setting off. 2011 CSW XS 90 |
11th Apr 2021 5:35pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 365 |
I had a Thermo-Top C in my Td5 for years and my experience was pretty much as described - 2/3rds of the way to normal operating temperature ‘on the gauge’.
The Webasto kicks in when the water temperature drops below 60C and cuts out at about 72C, so it all make sense when you think that most diesels run at about 82-86C. I’m looking forward to the FBH in my new 300tdi - this time I’ve gone for an Eberspacher for a variety of reasons but they all operate on the same principles. I’m looking forward to jumping into a warm and defrosted vehicle in the mornings - even if that’s much less frequently after the pandemic had changed my working practices for the better. Dave Gracie - 2015 110 XS County Station Wagon |
11th Apr 2021 6:55pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 673 |
Thanks all that's superb feedback. I guess what I'm really pleased about is having rebuilt mine before fitting it is working as we'd all expect it to.
Left it running on the drive till it tripped out earlier just so I knew it would and all is well. Five minutes later it tripped in again as the block started cooling. |
11th Apr 2021 7:33pm |
Fair play rebuilding and fitting yourself - I had a look, but it was too daunting.
I ended up buying the specific Defender version and having it professionally fitted which cost an arm and a leg! Even with the cost, I still feel very smug when I go out on a frosty morning and the truck is ready to go, while the neighbors are scraping ice / demisting their windows; so you must feel super smug sorting it yourself!! 2011 CSW XS 90 |
11th Apr 2021 8:28pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7686 |
Mine gets to 40 deg after 15mins running and around 60 degrees after 30mins. Working from 5 degrees ambient.
Based on 3 vehicles each having a thermo top fitted to 2.4s, Reading coolant temp off scanguage. Heater on full heat, fan off. When its 15/20 degrees ambient, 40/45deg coolant temp after 10mins, which is perfect for the heat exchanger for onboard shower. None of mine drop from horizontal temp reading once up to temp though unless it's 3ish degrees or less. If yours comes down so quickly maybe check thermostat Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Apr 2021 9:34pm |
Cheers jst, I'll have a look tomorrow morning.
Is it easiest to start the truck (after the webasto gets up to temp), let it run for a minute or so and the gingerly touch the rad? If the thermostat is shagged, I think I'll go with one of the 82 degrees version (PEL500110). 2011 CSW XS 90 |
11th Apr 2021 9:46pm |
JST that reference to none dropping below normal midpoint on the gauge once up there, what is the vehicle heater doing at that point are you using it or is it turned off? Wondering if you used the vehicle interior heater you'd then get the drop in gauge reported temperature I/we seem to be getting.
11th Apr 2021 10:21pm |
I use my webasto to preheat prior to start or to maintain heat if parked up, engine off. , I don't run it when the engine is running. ( two water pumps at different speeds)
I get a slight drop in temp after startup, less than 10deg but it climbs back within couple mins driving. Heater set to full heat but I don't turn fan on until engine is at operating temp. It then stays horizontal unless 3sh deg or less and sat in traffic. I leave fan off to concentrate heat to the block. Heated seats and an air top provide cabin warmth. I also keep engine revs lower until fully warmed up. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
13th Apr 2021 8:06am |
took a photo this morning to show all the stats from my thermo top. it was run for 25mins prior to starting.
Click image to enlarge Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
16th Apr 2021 6:23pm |
Superb shot, thanks, that's really reassuring as that's exactly where I'm ending up.
16th Apr 2021 6:28pm |
Where does it infer its intake air temperature from, is it the MAF or post turbo?
Just wondering how reliable that would be to use after a while driving. |
16th Apr 2021 6:50pm |
not sure it doesnt change a great deal with engine use/heat. only time you see an increase not expected with ambient is when stopped turned off after a run with heat under bonnet. (as to be expected) Cheers
16th Apr 2021 8:19pm |
