PUMA - Access to Steering Box Adjustment
Is there another way to get access to the 'free play' adjustment screw other than having to strip out all the plastic radiator cowling?
10th Apr 2021 2:01pm
Remove the wing.
10th Apr 2021 3:22pm
llessur
There is a hole in the radiator cowl plastic adjacent to the adjuster. I pop the top of the cowl off, stick a spanner through the hole to slacken the locknut, then use an allen key socket on a long extension fed down from the top, at the side of the intercooler hose/ radiator cowl, onto the allen adjuster bolt in the steering box.
You can see the hole in the image below
