Home > Td5 > TD5 occasionally not igniting
The wildest man in town
Sweden 1999 Defender 110 Td5 PU Coniston Green
A really enjoying thing has happened two times last week. I turn the key to step two, everything seems normal (all lights comes on and I hear the fuel pump) but when I try to ignite, it doesn't fire and a the outer temperature display (I think this is not standard?) shines up a little and then turns off.
I was thinking the battery was running low for some reason, but after cursing for about an hour, I tried to start her again, and it worked. Which is really strange. I didn't do anything, just waited, and it worked.
The other time I was able to get help from two nice men to push her to start.
Any ideas of what this could be? Might be a good thing to check the battery?
Thanks!
Post #896872 9th Apr 2021 8:45am
landy andy
To clarify. Are saying that the engine turns over and doesn’t start, or are you saying that it doesn’t turn over?
Post #896876 9th Apr 2021 9:14am
It doesn't turn over.
Post #896879 9th Apr 2021 9:29am
davidblythe
time to overhaul the starter motor
repair kit of ebay less than £20 1999 90 TD5 CSW
2006 110 TD5 HD Commercial
Post #896922 9th Apr 2021 12:37pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Also check the smaller exciter wire on the starter motor, quite common for a loose connection. Had two in last couple of weeks at work. It’s just a normal 1/4” spade, that becomes loose. Hope you manage to get it sorted,
Ashbyandy 👍
Post #896923 9th Apr 2021 12:51pm
OsloBlue
Is it single clicks or multiple clicks?
Multiple is voltage issue, single is starter issue. I'm on IG: https://www.instagram.com/osloblue42/
Post #897054 9th Apr 2021 7:45pm
landy andy
Check starter motor as above, and also check that the fuel pressure regulator isn’t leaking on from above.
Post #897089 9th Apr 2021 9:03pm
