Home > Puma (Tdci) > 2.4 Turbo Replacement
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I've done some looking around but couldn't find much on the subject.
Has anyone done a turbo replacement on a TDCI 2.4? Are they bad to do? Looks like it should be fairly simple, as long as the bolts come out alright! Rolling Eyes
I'll be doing oil and filters too, is there anything else except the oil lines that will need including? Worth getting replacement bolts for the exhaust manifold? Think I've already got a gasket for it..
Turbo seems to have a bit of resistance at a certain point when turning the spindle by hand. Struggles to spin up so no boost unless thrashing it, but as soon as its spinning you can keep it going by staying on the boost.
Post #896768 8th Apr 2021 8:18pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Quote:
"as long as the bolts come out alright..."
Yep, good luck!
Worth fitting an uprated gasket while you're at it. https://www.4x4overlander.com/product/naka...-gasket-2/ WARNING.
This post may contain sarcasm.
Post #896774 8th Apr 2021 8:28pm
landy andy
You will have to remove the studs to get it out, which is a bloody stupid bit of design, so possibly get spare studs.
Post #896786 8th Apr 2021 8:43pm
BenB8man
Yup, so I've got the Naka gasket already. I've got oil feed, all bolts, studs and gaskets.
With the turbo included, all from LRDirect, it coming in at £601 inc VAT. So a good £700 cheaper than getting the cheapest garage to do it. I wonder if I'll regret that when I'm halfway through the job with 3 rounded studs. Whistle
I think I'll start soaking those nuts in penetrating fluid tonight! Laughing
Post #896805 8th Apr 2021 9:19pm
landy andy
It’s a really easy but annoying job. You’ve just got to remove stuff that is in the way as it wasn’t designed for the vehicle.
Post #896825 8th Apr 2021 10:04pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Just replacing mine too, I managed to do it without removing the exhaust studs.
Is it really critical to replace the oil feed pipe ?
Post #914820 30th Jul 2021 9:21pm
