Home > Off Topic > Best way to graft fence posts together?
Co1
I need to extend some fence posts, ideally by cutting them off low down and fitting new posts that match the panels. I really don’t want to have to dig out the concrete bases if I can help it. I have some galvanised 40mm angle that I was planning on using on all 4 corners and contemplated dowling the centre as well. Any thoughts?
Post #896527 7th Apr 2021 6:04pm
Ianh
I’m assuming these are 100mm wood fence posts. Cut existing and new post at a sharp angle that covers about 18 inches . Wood glue and Clamp them together and then use 75mm number 14 screws thin sides into thick sides. If old post and new post are the same size and you cut accurately and not out of square then you should get a joint that’s strong and not that visible.
Ps. Marking cut on both sides and using a circular saw makes it easier to get a straight and square cut.
Alternatively you can get square box section post joiners as well as angle iron ones.
Post #896530 7th Apr 2021 6:50pm
Co1
Here’s Ian, yes 100mm posts.
Post #896532 7th Apr 2021 6:56pm
Ianh
If you have a trolley jack it’s easy to get the posts out with the big lump of concrete attached without any need to dig Very Happy
Post #896534 7th Apr 2021 7:07pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
With a graft it will add strength if you drill a big centre hole in both and dowel them. Flat or angled doesn’t matter
You could simply buy post extender joints Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #896536 7th Apr 2021 7:33pm
jst
cut it off, dig it out of the concrete if not already rotten and drop new post in existing concrete 100x100 hole Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #896538 7th Apr 2021 8:04pm
