![]() | Home > Td5 > Intermittent battery warning light TD5 |
I think your brushes of the alternator are worn and/or sticky. Roel
Tufty Member Since: 27 Nov 2020 Location: Near Guildford Posts: 19 ![]() ![]() ![]() |
Thanks Roel, I now have a friend looking at it tomorrow so I will mention that!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
On the TD5 the vacuum pump for the brake servo is attached to the front of the alternator and it is a fairly common problem for the seals to fail allowing oil to leak from the vac pump into the alternator, forming a horrible gritty gungy mess which causes accelerated brush and slip ring wear. As the alternator starts to fail, you will initially get an intermittent warning light, then a complete loss of alternator output. It would be worth checking for this (look for oily yuk all over the alternator).
Sadly it doesn't seem possible to get the parts to overhaul a TD5 alternator in the UK (slip rings and brushes, etc) nor the seals for the vac pump, so total replacement is usually the only answer. |
Thank you Blackwolf, this is really helpful. I had hoped it might not be terminal as the problem is intermittent, but I feared it may be!
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
https://www.unitexchange.com/
Have used this lot from S1 through to TDCI and they are old skool brilliant. Normally have a refurb starter or alternator on the shelf, but if not rebuild in less than a week. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Thanks familymad, I will look into this.
