Home > Maintenance & Modifications > Convenient Earth Point?
Hello folks,
I'm part way through designing a loom for a headlight wiring upgrade and spotlights. Part of this will see a reasonably substantial cable run from the battery positive to a busbar fuse box to be mounted on the inside of the left hand wing, just forward of the heater intake duct. Before I plan the same for a negative cable, can anybody point me to a convenient earth point around that same area that's easy to access? I don't want to run a cable to the engine.
Thanks. Darren
Post #895064 31st Mar 2021 11:12am
excossack
On the TD5 there is a earth on the chassis under the battery box. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #895070 31st Mar 2021 11:35am
kmac
There are a few earth points on the bulkhead inside the engine bay.
Post #895086 31st Mar 2021 1:11pm
Thanks chaps. The chassis under the battery box is a good call. I did look at the ones on the bulkhead but they're already quite congested and I'm not sure that the size of cable that I need would be an easy fit. Darren
Post #895105 31st Mar 2021 3:16pm
