Home > Td5 > Slimy balls
landy andy
Slimy balls
Thinking of rebuilding my swivels as they are leaking a little bit of grease, and I’m going to be in the area as I’ve got new discs, pads, and callipers to fit whilst I fit a new diff
Are these the correct bits for a late (06) 110with abs? And are these the quality balls that they used to be r has quality dropped since I last did some.
https://www.paddockspares.com/da3180-swive...h-abs.html
Post #894243 27th Mar 2021 1:06am
Dinnu
I bought a similar, but without balls kit.
I will be discarding the lower bearing from the kit, unsure if I will reuse the original lower bearing or get a decent quality one. My top bearing is the railiko type. As for the seal, I got corteco replacement. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #894258 27th Mar 2021 8:23am
landy andy
These ones come with Corteco seal and Timken bearings, so look better.
https://www.lrparts.net/catalog/product/vi...gory/1026/
Post #894267 27th Mar 2021 9:47am
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Re: Slimy balls
With Paddocks, add a “G” after the part number for the kit with OEM components....including Coteco and Timkin bearings.
Search for .....DA3180G
Patrick
Post #894604 29th Mar 2021 2:11am
