![]() | Home > Td5 > Rr springs on a td5 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
See http://www.red90.ca/rovers/springinfo.html
The range rover had some of the softest spring. The column "Rate" in lb/inch is how much load is needed to compress the spring by 1 inch. So the lower the number, the softer the spring. If you go for softer springs, you need to compensate in length (or use spacres) else, it will be sitting lower. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8372 ![]() ![]() ![]() |
Rrc police spec springs were always the cheapest go to option for soft springs, slight height gain and great articulation. Cheers
