![]() | Home > Faults & Fixes (L663) > Cruise Control problems ? |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
What do you mean by failed to work? Could you not turn it on? Set, reset? Or did it just stop working (ie dropped out when active) Steve N | 21MY Defender
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1141 ![]() ![]() |
Not had any issues with it at all. Great system. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
defender_uk Member Since: 12 Aug 2011 Location: SW Scotland Posts: 197 ![]() ![]() |
you need to check that Cc is activated and not the speed limiter. Caught me out when I first picked it up. Works on the same button the steering wheel and you have to toggle between the two. 2020 First Ed 110.
replaced by 2021 250 110 Commercial Defender_uk |
lootawi Member Since: 21 Mar 2021 Location: dubai Posts: 4 ![]() ![]() |
nope it just doesn't function ! i toggle between the CC and the LIM the limiter do work properly every time unlike the CC, just fails to function i cancel and try to switch on (engage) but still doesn't !! strange it even gets worse by time. a ratio of 90% of the times i tried engaging it, it fails to work ! i have to stop the car turn it off and start again to engage it. somehow strange ! |
does not work ! trying set, reset +/- nothing does work ! and once i engage the LIMITER works fine but when i turn back to the cruise control it doesn't unless i switch off the car and start it again !. |
i toggle between both LIM does work fine ! but not the CC ! |
