Home > Technical > How should it be done?
landy andy
The carpet on the front of the seat boxes on my Td5 110 looks wrongly fitted, and likely to attract moisture inside. So I’m just putting it to how I think it should be. But now that looks wrong.
How is your done?
Post #892802 20th Mar 2021 2:37pm
I'm not sure which is photo "before" and which is "after", but the top one is how it should be, carpet above the floor panel.
Post #892809 20th Mar 2021 3:11pm
landy andy
That was my thinking. Carpet should be out.
Post #892848 20th Mar 2021 7:16pm
Dinnu
Off topic, but slightly related. the 3 bolts on each side of the seat box that bolt to the sill channel, on Td5s the washers clamped the carpet.
On the later tdci, the carpet covers the bolts.
Indeed, the carpet should be above the floor boards.. also not clamped by the self tapping screws that fix the floor board. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #892851 20th Mar 2021 7:25pm
landy andy
Didn’t know that either. Had rubber matting before, not all this posh carpet.
Think I preferred the rubber. Might swap it at some point.
Post #892854 20th Mar 2021 7:29pm
Julie
Re: How should it be done?
landy andy wrote:
how is your done?
The sheets are fit tightly on the frame. Not that loose fit shown on that photograph Neutral
I believe there was even some sort of mastic in between - but I have to look this up
I have carpet and not the tiniest little trace of water inside
Post #892874 20th Mar 2021 8:49pm
landy andy
Though that was the case so have swapped both sides so carpet now on the top.
Anyone know who makes rubber version, so I can swap for the carpet?
Post #892876 20th Mar 2021 8:53pm
