Home > Td5 > Clutch pushrod
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Clutch pushrod
Hi.
After changing clutch and flywheel ( Valeo) on my 2002 td5 I been having issues with the clutch..Everything was changed - except slave and master cyl as there was no issues with them.
I had to adjust the master cyl. all the way out to get somewhat decent clutch .... the pushrod I installed is FTC 5199....I was about to change both slave and master + hose, when a friend of mine mentioned that there is 2 different lenghts of pushrod????
Anyone knows something about that๐Ÿ˜ฌ
Regards
Christian 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #892508 19th Mar 2021 8:22am
Pacha
There are 2 pushrods, one is 99mm long (FTC5199) and the other is 105mm long (FTC3192). Rgds.
Chris
Post #892555 19th Mar 2021 12:54pm
CRJ
Thanks - I Will try FTC3192๐Ÿ‘๐Ÿป I bought FTC5199 as it was said to fit all Defender Td5 ๐Ÿค”
Regards
Puma 130 - 08- sold
110 CC 2003
Post #892641 19th Mar 2021 7:51pm
I had exactly the same issue when I built my 110 back in 2010....
bought a slave cyl, thinking "ah, Td5 and 300Tdi are the same".... not....
I had a slipping clutch issue from day 1... just looking at the clutch pedal would cause a slip...
Think the slave cylinder also had a deeper "hole" in the end of the piston as well, but as said above, the Td5 is different (shorter) so it gives a little more slack in the system... or just not pressuring the friction plate all the time.
Post #892648 19th Mar 2021 8:13pm
CRJ
Weird.... I have the opposite problem... i have pressure on the pedal but it feels Like the clutch is not pressed all the Way - I am having a hard time changing gears๐Ÿค” 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #892858 20th Mar 2021 7:55pm
CRJ
I just changed the master cyl.... I got a brand new car ๐Ÿ˜€.. After close inspection there was a tiny bit of brake fluid on the pedal. I was certain it was the pushrod or something else as the movement in the clutch pedal felt normal...guess it did not produce enough pressure to function properly.
Regards
Puma 130 - 08- sold
110 CC 2003
Post #894507 28th Mar 2021 4:11pm
