![]() | Home > In Car Electronics > Using the under seat fuse box for accessories |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1496 ![]() ![]() ![]() |
Rather than risk overloading anything in the original fusebox or it's wiring, I'd fit an auxiliary fusebox under the driver's seat.
Run another supply back to the battery for the aux fusebox. If you've not done the security upgrade of rerouting the main fuse box supply to inside the body, I'd recommend doing that. Then use the old supply for the new aux fuses, it won't matter then if it gets cut during an attempted theft. |
