![]() | Home > Puma (Tdci) > rear anti roll bar bolts are gone |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2495 ![]() ![]() ![]() |
have a look also to the bolts from the rear disc shields. They also get loose and cause the plate to crack and bang Puma 110" SW
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Got the landy back today.
All work done on waranty. Also got the handbrake recall done. That weird clunking noise when you shift are now gone!!!! HOOORAYYYY ![]() |
Marius, try loctite on them 2.4 90 XS
Has anyone else lost them?
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
I lost mine with the help of my tool kit. Far better vehicle to drive.
Allan |
Why did you take them off? Mind you I dont think older defenders have that anti roll bar? I could be wrong?
I wanted more travel, fitted relocation cones and after market shocks. It also rides a little softer without them. Allan |
