![]() | Home > Technical > 2010 Puma w/ABS brake pedal just keeps sinking... |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
No that is not normal Samblers - you should not be able to press the brake pedal all the way to the floor with the engine running.
I would suggest that you do have air in the system. When the engine is off, you will not have the vacuum assist which the engine is providing, meaning you would have to press the brake pedal a lot harder for the same braking force. When you are bleeding the system, can you confirm the method you are using? It sounds like you are not using the electronic "get the ABS unit to bleed each corner" approach. I don't know how successful a manual bleed is on an ABS equipped vehicle is. 2005 Td5 90 XS 1989 V8 110 CSW |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
Had exactly same when replacing callipers on td5 with abs bleed fine with pressure bleeder at callipers but no firm pedal with engine running so re bled using the abs calliper bleed and power bleed and was fine after sometimes air can get trapped in the abs
Samblers Member Since: 29 Jan 2014 Location: Perth, innit Posts: 63 ![]() ![]() ![]() |
Thanks guys,
Yes i'm starting to suspect the ABS module has air in it. I would add that when i did discs/pads i lost all the fluid because I undid the brake line union on the first wheel to gain access (rookie error). I bled using the old-fashioned method. I also just found the trailfitter video about brake bleeding process here: - which is for ABS defenders, and involves bleeding the ABS module using an interface (which I dont have) So, presume I should just take the car to a LR mechanic and get them to perform the ABS module bleed? Cheers, Sam |
