![]() | Home > Technical > Puma aux spotlight switch. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
I am after some advice please.
I am attempting to wire in a puma/td5 style light switch. Electrics are not my strong point. I understood the switch worked by switching a relay to earth which is how i wired it but it didnt work. i searched and found this https://www.defender2.net/forum/topic64891.html i have wired it with a relay as suggested in the above topic. Click image to enlarge Click image to enlarge i have put black to earth Red/yellow to dash lights Blue to earth side of relay pin 85 blue yellow to pin 87 12v to pins 30 and pin 86 I get illumination lights, i have 12v at pin 1 going into the switch switch in or out i get nothing else If i pull the blue and yellow to pin 87 and just apply 12v to it, then i get red indicator light on. i have no continuity between pin 1 and pin 3 or 4 with the switch pressed in which i was expecting. Am i missing something or is the switch goosed? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
Sounds like it's the switch if 1 and 4 aren't connected when the switch is pressed in.
If you want to check your wiring is sound, use the rear fog light switch temporarily (but you'll need to hold it in). Apart from being momentary action, it works exactly the same and takes the black connector. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
With the switch pressed, you should get continuity between pins 1 and 3/4. If you're not then it won't pull the relay in, which is backed up by the fact you can get the red LED on by applying 12v straight to pin 5. On the face of it, that does sound like a problem with the switch.
They're quite easy to take apart to reveal the internal tracks and the switch mechanism, which is probably a worthwhile exercise. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Many thanks. Wiring works when switch replaced with fog light switch, so seems switch is at fault. Will pull it apart as suggested. Cheers
| All times are GMT |
