Home > Faults & Fixes (L663) > Noisy Driver side A-pillar
abpod
United States
I thought I had read this somewhere else but I could be wrong. My driver side A pillar is very noisy when the vehicle is in motion. Disappointing for a brand new car. It sounds like a twig tapping a window pane or sand trickling on a hardened surface.
I’ve pressed my hand to apply pressure at different points along the pillar trim and corner dash but the sound does not stop. I also thought it might be the door frame stereo tweeter but no. It seems to be underneath the A pillar trim piece.
Anybody else with this issue? Find the culprit and/or the fix? '21 L663 X-Dyn HSE P400 Carpathian
'13 L319
'03 L322
Post #888576 2nd Mar 2021 3:00am
J77
Try this Thumbs Up
 24MY 90 D250 HSE, Tasman Blue
Post #888577 2nd Mar 2021 6:17am
Retroanaconda
It’s the trim on the outside of the A pillar. There is a factory bulletin for it, the dealer will be aware and will be able to apply the fix.
The B pillar thing in the video above is a different noise.
Post #888585 2nd Mar 2021 9:06am
Tim in Scotland
I had a rattle inside the B pillar that wasn’t the window shaper thing, the local dealer fixed it while the car was in for something else to be fixed and I haven’t had that rattle since. I don’t know how it was fixed but suspect it was something in the seatbelt mechanism or the belt webbing vibrating Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #888597 2nd Mar 2021 10:49am
SSM 75038 - L663 20MY Tapping Wind Noise from A-Pillar Area
It was also subject to earlier communications:
SSM 74826 - Tapping Wind Noise from A Pillar 21st May 2020
SSM 74826 - Tapping Wind Noise from A Pillar 23rd June 2020
Technical Topics - Body - Tapping Wind Noise from A Pillar Area
Service Action N472 - Technical Bulletin - Tapping Wind Noise from A Pillar Area 11th August 2020
The latter being the most useful of the former documents:
Post #888599 2nd Mar 2021 10:59am
abpod
United States
wow folks! Awesome stuff!!! Thank you!!! '21 L663 X-Dyn HSE P400 Carpathian
'13 L319
'03 L322
Post #888676 2nd Mar 2021 7:55pm
Simon Audi
Is there any more recent bulletins than this - only the Parts fitted to the car are AD version - so later than mentioned.
L8B2-03178- AD and L8B2-03179-AD
Covers were already a tight fit - sliding on / off.
Thanks
Post #909778 28th Jun 2021 12:11pm
My first search suggests that this is the last NHTSA posting, on 21st June 2021, more may be available on Topix:
Or email Jerry Bennett direct Whistle
Post #909790 28th Jun 2021 1:19pm
Simon Audi
Thanks
Post #909791 28th Jun 2021 1:25pm
Simon Audi
Well I emailed Jerry Bennett - No Answer yet...
Post #910269 1st Jul 2021 11:59am
Shame ~ I've emailed a few in the past, most ignore but a couple of replies have gone a long way to restoring some faith that there are decent people in the company.
Post #910272 1st Jul 2021 12:25pm
Simon Audi
Lets give him the benefit of the doubt that he may be on holiday for a few days.
Hopefully he will reply next week...
Post #910273 1st Jul 2021 12:46pm
Simon Audi
Still no answer from Jerry.....
Post #914263 27th Jul 2021 2:30pm
AndrewS
Was there ever a bulletin ref the B pillar noise? well not the B pillar but the drivers door rubber top corner where the window goes up into. So its B pillar area but not the B pillar. My car has developed a noise like a hair dryer it starts at 50mph and gets louder as the speed increases. If I touch the rubber it stops the noise. I end up wedging my covid mask between the glass and rubber to stop it. 130's have feeling's as well you know Smile
Post #933461 13th Dec 2021 7:07pm
Simon Audi
Mark on here posted videos - basicaly use some black silicone and stick the rubber pad to the car door insulation behind the rubber.
Post #933462 13th Dec 2021 7:10pm
