Home > Maintenance & Modifications > Brit Part Double-Cardon front prop shaft
Drover
Australia
Hey Guy's
Picked up a brand new Brit part Double Cardon front prop shaft at the right price on the weekend.
It looks good and strong, but I am wondering if anyone has had any experience with this shaft or comments prior to me fitting it.
I have a 2" lift on the PUMA. I have not had problems so far but I am about to replace the standard shocks with extended versions and the extra down travel may cause bind on the uni's.
All thoughts comments welcome.
Post #83527 9th Aug 2011 4:49am
leeds
The general Opinion from mechanics
I know is that on a 2" lift then a double Cardon is not normally needed. Extended brake hoses would normally be the only the additional required item needed.
Have 2" lift on one of our vehicles and do not have problems with UJs. No anti roll bar
One idea is to hoist vehicle up and let the axles reach max droop and check it out carefully.
Since you have it why not check droop with Cardon shaft not fitted and fitted?
Brendan
Post #83543 9th Aug 2011 9:12am
RED-DOT
My Disco2 automatic had a DC prop from brand new and it caused a vibration at 70mph and it went away at 80mph, very annoying. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #83554 9th Aug 2011 10:55am
landy andy
I thought that you should not lift a Tdci any more than an inch due to g box being at a strange tilt.
Andy
Post #83634 9th Aug 2011 8:47pm
fekete
Hi I have a 2 to 3 inch lift with no problems... Thumbs Up you will get all the Censored you need on here about don't lift it you will hurt it Rolling with laughter Rolling with laughter talking through there bottoms NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #83646 9th Aug 2011 9:19pm
