Home > Maintenance & Modifications > Fitting 52” light bar to Flatdog RAX roof rack
battle-defender
England 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
After taking receipt of the 52” light bar it became clear the supplied brackets would not fit directly to the Flatdog. Looked at their light bar fitting which is a neat way of securing. This would not work as the 52” is too wide.
Decided not to drill into the Flatdog frame. Chose to fabricate a metal plate sandwiched between the leg and the frame and all bolted together. Quite a lot of adjusting and easing required.
Quite happy at the result. Defender 110 XS SW Puma - 2011
Defender 110 XS SW - 56
Post #886590 19th Feb 2021 7:35pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I like the look at that Thumbs Up still not fitted mine yet Sad
Post #886609 19th Feb 2021 9:00pm
battle-defender
Thanks Stew.
Look forward to seeing how yours works out. Defender 110 XS SW Puma - 2011
Post #886699 20th Feb 2021 10:54am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
I have a similar issue with a mates 90 I'm adding bits to. He went out and brought a 52" lightbar before i had the car off him to fit OE LR roof rack. The rack as its own spot light fitting mounts but nothing there to fit the 52" jobbie. I don't really want to drill the roof rain channel to fit those brackets available on ebay. Anyone seen anything that i can use without drilling, he's all for using cable ties lol... Putting Dreams on Drives at JLR Solihull..
Post #887001 21st Feb 2021 8:24pm
