![]() | Home > Td5 > door not closing |
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 108 ![]() ![]() ![]() |
Good morning,
For the past few days my 2003 TD5 has the driver's door refusing to close... Sometimes the locks hooks into the body but the door refuses to lock shut, sometimes nit even that... To make it stay close I need to put body pressure onto the handle from outside, or when inside, open the window so that I can slap the door handle with my hand... Any advice? Alex http://instagram.com/h4vou/ |
I will try, thank you.
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Also worth checking that the striker plate is tight and hasn’t moved.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3599 ![]() ![]() ![]() |
Check also the striker where the lock latches to. That part is covered in plastic and if it wears of, then it’s effective diameter will be smaller and would not be able to push the latch sufficiently to lock. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
will check, ta!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
All working now that is warmer...When it stops raining I will apply brake cleaner and re lubricate with graphite powder as suggested.
Thank you for your help A http://instagram.com/h4vou/ |
