Home > Technical > Difference between 10P and 15P TD5/Puma Radiators
rallysteve
Does anyone know what the actual difference is between the two different radiators please?
Seems that there are two different part numbers but aftermarket radiators (Nissens) looks to be just one radiator to cover all models.
My 15P radiator has the two main radiator pipes, small bleed pipe in the top corner which goes back to the expansion tank and a small outlet on the front lower corner which is piped back to the fuel cooler.
I realise that the 10P doesn't have the EGR cooler but have never looked at the cooling system on one to know how the pipe connections/routing differs. Just want to check that I wont have any issues with an aftermarket Nissens radiator.
Cheers,
Post #884942 12th Feb 2021 12:41pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Is one potentially for the 2.2 Puma that runs a DPF therefore needing a different cooling capability to allow regen burn off? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #884944 12th Feb 2021 12:46pm
Martin
Site Admin
Little bit here: https://www.defender2.net/forum/topic29789.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #884946 12th Feb 2021 12:50pm
rallysteve
Dont think so,
Nissens online catalogue lists their rad 64311A to be for:
PCC001020 - TD5 from 2A (15P) and all 2.2/2.4TDCi
PDK000100 - Td5 to 2A (10P)
PCC000670 - Td5 to 2A (10P) superseded by PDK000100
PCC107480 - Td5 to 2A (10P) superseded by PDK000100
So looks like it is one radiator for 15P TD5 and all tdci but a different one for earlier 10P TD5s
Cant see any real difference between them from online pictures. Confusingly though Island4x4 show different listings/prices for a 10P and 15P nissens item though.
Cheers 02' 110 TD5 Double Cab Rebuild Thread
Post #884949 12th Feb 2021 12:55pm
Martin
Site Admin
Nissens bulletin: https://customerportalmedia.nissens.com/fetchfile.aspx?id=23753
Their part 64311A is listed as a replacement for all Td5 rads, looks like they supply a restrictor and the stubs for the cooler are blanked off on purpose (and shouldn't be opened)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #884950 12th Feb 2021 12:56pm
rallysteve
Thanks Martin, crossed posts!
Looks like the same query I am having. I will give the cheaper version a go and see if it is correct.
Post #884951 12th Feb 2021 12:57pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I've got the Nissan radiator on my 15p td5. no concerns.
Post #885081 12th Feb 2021 9:06pm
Mo Murphy
@rallysteve
How did this turn out in the end Steve ? Did the 10P rad have the cooler stub blanked off ?
50 Shades of Pennine Grey
Post #975042 18th Dec 2022 10:50am
rallysteve
In the end, I just bought the Nissens one from Eurocarparts which fitted onto my 15P fine. Came with a restrictor for the fuel cooler (although mine only had one fitted.
As advised, it has the port on the bottom rear of the radiator (drivers side) there but blanked.
Also came with new mounting rubbers which i recall to buy separately cost more than the whole radiator Rolling with laughter
Post #975050 18th Dec 2022 11:55am
rallysteve
This was the Nissens number from the box
Post #975289 20th Dec 2022 6:54pm
Pacha
Had a Nissens on my Puma 2.4 for over a year with zero issues. Rgds.
Chris
Post #975293 20th Dec 2022 7:23pm
Mo Murphy
Thanks Steve 👍 I think I'll pay the extra and get a Nissens radiator.
Post #975312 20th Dec 2022 11:07pm
