![]() | Home > Maintenance & Modifications > interior trim disintegrates |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Hi sorry your having problems, is it possible to explain a little more or perhaps include some pictures so people can offer you some advice. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 ![]() ![]() |
here are the pictures
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
Wow. I don't think I've ever seen similar pictures, where the matting has separated. I wonder if there's something in your local environment chemistry that's causing that?
The wear in your second picture - at the front of the seatbox is very common - that's just peoples' boots and shoes rubbing against it over time. If you replace it, there are various 'corner protectors' you can buy. In my car, for the seatbox and floor/bulkhead I have the Wright Off-road accoustic matting. It's a very resistant Polyurethane mat. I haven't got any pictures on this device, but if you look at my rebuild thread you should find some, or just google. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
My 1988 90 had hardura in centre part of bulkhead and transmission tunnel. The transmission tunnel started to crack and fall apart after about 10 years. The bulkhead part survived a bit more, but now after 33 years they went all crumbly. Their foam backing however are as good as new.
In their life I used to only wipe them with a moist cloth. Never used any aggressive cleaners. But they had seen quite some sun shine, which I think dried them out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I hesitate to take the carpet to redo the interior. I saw at exmoor trim.
the best should be that I find the rubber kit is not too expensive |
