![]() | Home > Puma (Tdci) > error code p037d |
| dazzling1611 Member Since: 08 Jun 2020 Location: morpeth Posts: 35
yes it sounds like a glow plug fault, check the feed into the glow plugs from the relay is ok , then check the resistance on each glow plug.
its either a electric issue or faulty glow plugs. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
2.4 puma engine glow plug cct have feed back too the ecm, if the glow plug relay is removed and ecm call for glow plug no feed back will be given and DTC p037d will be logged also blown fuses in this cct will stop relay from closing and DTC p037d will be logged
pos 2012 2.2 engine puma glow plug cct have glow plug ECM also check resistance on each glow plug. proxy 0.9 ohm each |
| nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80
I put another relay twisted a little the legs and for the moment it works
