![]() | Home > Maintenance & Modifications > Question about hand brake |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Potentially sounds like your handbrake cable is starting to seize up or your handbrake mechanism is sticking. The cable/mechanism probably frees up with the exhaust heat or from the shoes dragging if it is the drum itself.
I would remove the handbrake drum and have a good check of the mechanism, make sure springs are all present and even better clean it up and apply a small amount of copper slip where the shoes rest on the backplate. Also check that there are no signs of damage to the cable and that it hasnt been bent excessively tightly where it is routed. Steve 02' 110 TD5 Double Cab Rebuild Thread |
tomsorrente Member Since: 04 Feb 2021 Location: Capbreton Posts: 6 ![]() ![]() ![]() |
Thanks a lot for these explanations, I'll try to do all of them and will keep you updated !
Thomas |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
Salut Thomas
Retirez votre tambour de frein à main, il est peut-être plein de saleté. Excusez mon français, je suis anglais. ![]() ![]() Marc. |
ok merci !
