![]() | Home > For Sale & Wanted > [For Sale] Core heater with fan for a webasto thermotop |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
If you seen my hot water/ heating system, you may have seen this, if not then go take a look
![]() It’s a core heater with a fan attached, useful if you have a webasto thermo top installed as it can be fitted within the route of the pipe work to provide warm air by using the heated water to heat up the core which then has the fan to push the warm air into wherever you like. I had it in my set up and all working but I’ve swapped out this for an airtop and I’m keeping my thermo top for hot water only, this way I keep all systems separate 👍 £40 is what I paid for it, so I’m asking the same. Postage will be about £6 Cheers ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688 ![]() ![]() |
-- edited and deleted - asked a stupid question you answered in your first line of your post!! --
