Home > Puma (Tdci) > More gearbox woes
audi1boy
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Barolo Black
More gearbox woes
So after having issues with a whirring sound when the clutch was engaged and in neutral, clutch pedal up I removed the gearbox and changed the clutch release bearing..... Still had the noise.
So i bought a reconditioned gearbox and transfer box from Simmonites believing that it was the input shaft bearing on the gearbox. When i removed the old gearbox there was a huge amount of play from the rear output shaft as is common and when draining the oil from the transfer box the sump plug was covered in metal. So it needed doing urgently.
So I felt confident that this would sort it.
After finishing and leaving the truck running it still has the whirring when up to temperature from the gearbox.
Is it a duff gearbox or the whirring is coming from somewhere else? The flywheel bearing its about all thats left and that is under the same load wether the clutch is in or out.
TIA
Post #880821 25th Jan 2021 6:13pm
LR90XS2011
does it go away when stationary with the clutch pressed? DEFENDER 90 TDCI XS,
Post #880851 25th Jan 2021 7:39pm
audi1boy
Hi,
Yes when you depress the clutch it goes away.
I guess it happens when its in gear with the clutch up but due to the noise of the vehicle you can't hear it.
Its a 2.2 TDCI 2013 110 sorry didn't say
Post #880853 25th Jan 2021 7:46pm
LR90XS2011
think you might just find it is a normal rumble quite common due to the crap clutch design and a resonance that can set up in the gearbox, if its all fairly quiet when being driven I wouldn't worry too much
clearly this is without hearing it DEFENDER 90 TDCI XS,
Post #880855 25th Jan 2021 8:05pm
audi1boy
Thanks mate that makes me feels somewhat better.
Ill upload a video later if i can to see what you think. I did have to chuck the sound deadening from around the turret as it wasn't in good nick. So will try to renew that to help.
But at the moment my old L200 purrs like a Bentley compared to this thing Laughing
Post #880925 26th Jan 2021 8:12am
GabrielPaterson
South Africa
MT82 6 Speed Gearbox
Hi there all,
not too sure if this forum is still active but i was hoping someone could assist me, i am doing an electric conversion and am still using the original MT82 gearbox so i obviously need to make an adaptor plate.
i have been searching the interned looking for the bolt spacing or bolt pattern on the face of the gearbox and unfortunately nothing , i was wondering if someone could please help !!
Post #882519 2nd Feb 2021 8:21am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
all those metal flakes might have blocked the oil pump. have you checked this ? there is a filter. By the way i know nothing about gearboxes just the basics
Post #882535 2nd Feb 2021 9:32am
