![]() | Home > Td5 > Td5 splutter/misfiring on high revs |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
What make of filters fitted.
Did it include fuel filter How quiet is fuel pump Injector loom changed recently Have checked/cleaned crank sensor Is misfire only since service? |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
Does it “kangaroo” whilst at high RPMs? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
Did it include fuel filter How quiet is fuel pump Injector loom changed recently Have checked/cleaned crank sensor Is misfire only since service?[/quote] Hi Andy I will check all the above👍🏻 iIt has had new filter when the service was done just before I bought it. Not sure what parts the used Not check anything was looking for pointers first 👍🏻 Driving under normal conditions it’s fine I had to go a run on the motorway that’s when I noticed. Cheers |
Yes is like power is coming and going👍🏻 Cheers Ash |
Try unplugging your MAF sensor. Charlie
Thanks I will
Give it a go👍🏻 |
If it is always at high revs check your turbo wastegate is freely moving, and I’ve known cheap fuel filters to restrict fuel
Sorry not replied any sooner Andy you was bang on the money.
it was a sticking wastegate ![]() |
Good news. Nice and simple.
